Newbie - Water and electricity?
19 Sep 2005
Kent
Hi all,
Handy place you’ve got here, I’m hoping you can help :D
I’d like to run a cold water supply to my garden - purely for watering-can filling purposes you understand.
The cold water supply in my kitchen is situated at the front of my house; the supply to the garden would be through the back wall.
The easiest way of running the supply would be through the bottom of my base units - clipped to the wall and lagged, but I have an electric oven fitted in the row, with a ventilation (?) gap at the back to the underside of the unit. There would be approximately 300mm between the pipe and cooker terminals.
Would it be possible to run the water pipe in this same space, with perhaps a deflector plate above it in case of a leak or should I look at another means of routing the pipe? :confused:
