newhome EL-906
7 Apr 2005
The bulb has blown in the main oven,how do I get access to change the bulb?
MOD
moved as posted in wrong forum
look near the bulb for screws or some sort of panel covering the bulb
Hi Breezer,the manual has gone missing over the years,I may have to resort to taking all the screws out of the front panel and go from there,wish me luck!
Hi Kevplumb,thanks for the advice I have had a look but the lens is sealed to the oven wall,hows the situation in Iraq?
Oven lens can be held on by spring clips, if this is the case you may see part of the clip on the lens.
If you can see a clip, use a wide bladed screw driver & gently lever the lens away from the oven side. There may also be a seal between the lens & the enamel.
