Any advice appreciated.
I recently fitted a new designer radiator in the living room - it's 1800mm high and 450mm wide. I've just noticed that only the left hand side is red hot and it gradually gets cooler as you get to the right hand side of the radiator. The flow comes in at the left and returns at the right. I did fit the trv to the return by mistake but it's bidirectional so should be fine. Ive tried bleeding the rad but there's no air in it. I've turned the other rads off but it made no difference.
I tee'd off the 22mm flow and return and ran the pipes in 15mm to the new rad.
Any ideas?
Thanks,
Rob
Any ideas?
Thanks,
Rob
