We've just had the loft insulated and it's freezing up there so I guess it's worked.. The only problem now is that condensation is building up on the inside of the loft roof.
yes it is caused by a lack of ventilation the edges must be clear so that air can flow through loft.
the end result of not doing anything will be rotting timber - deal with as soon as possible.
