Hello Sparkies,
i have Economy 7 at home, but since i have moved into the house, i have never seen them working in the night. I thought its just the Fuses might not be working , i replaced them but still its not On in the Night. I assume it only works in the Midnight to 7am,
Night storage heaters work fine when i use them with normal Rate during the Day but in the Morning i found they have not stored anything. SEcondly the Boiler also had no hot water at all. I left Night storage on in the night.
~The boiler also works fine, during the day on the Normal rate electric. I have got old style fuse box, which takes catridge Fuses. I have already replaced both 15amp fuses but still no Luck.
Could you please tell me, what could be the problem. I Test with Tester but Red and Black Wire both dont have Current in them. I assume the Night Storage only comes on in the Night,
As i have Two Seperate CCUs , one for Normal day , One for Night Storage. please see album pic for both of them.
I apprecaite your response in this regard. Thank you.
