Hi, I've got a problem with a PIR floodlight that I'm hoping someone can please help me to solve.
Just had an outside wall rendered, and during the prep, one of the builders very kindly removed the existing floodlight from the wall (after wifey showed him where the meter box was to turn off the power to it)! The trouble is that builder disconnected ALL of the wires from the terminals on the plastic connector unit within the light while he was removing the light from the wall.
The unit is a "Nightbrite 300W floodlight with 140 PIR". Now the light has been working fine for well for ages and I've only had to change one bulb in six years.
I tried to just call the helpline number on the instruction sheet, but they must have moved/gone out of business or something! (Ring Lighting in Leeds).
Can anyone tell me how to reinsert the wiring correctly so that I can put it back onto my wall please. I'll go and by a new replacement if necessary but it seems a bit of a waste to chuck this away.
I've tried to post photos of both the unit's wiring area and the wiring diagram from the instruction sheet that originally came with it, in the hope that these will help. I can use a meter to try and check anything but I'm not an electrician. I've inserted the obvious wires but don't know how to check where the other three (two white and one black are supposed to live.
Thanks for any help,
Paul
Paul
