Reminds me of an apprentice I worked with
For yellow rawlplugs and 25mm screws he used a 150mm sds bit all the way in and went right through the marble Listed staircase from underneath Ten Times.
cost thousands to repair it.
They were grey engineering bricks with holes drilled through the centres of the bricks.
(not in the courses) must have took ages, and in each one was a small 30mm deck light neon
