I've been doing DIY plumbing for 30yrs.............I'm no expert but I can do it.
I wanted to run plastic pipes (with pipe insulation too) under the floorboards because it can withstand freezing temps better and for the first time I'm using brass compression fittings with inserts in the pipes because a brass fitting will not leak but that O ring on a plastic pushfit will finally give up in about 40yrs time.
I've run the pipes, had the heating working for the last 3 days............BUT................every morning most of the joints are leaking, I tighten the fitting more and all is good for the day. The next morning the heating won't work cos the pressure has dropped due to all the overnight leaks!!!!!!!
3 days this has happened, I'm gonna have to rip out the plastic n use copper. Has anyone else had this? my inserts are plastic but suitable for compressions
