Nissan Serena lights left on warning buzzer.
7 Jun 2006
London
Hi All
I have a Nissan Serena 1.6 GX and I have noticed that the warning buzzer notifying me that I have left my lights on does not work anymore.
This has been a pain because the battery has died on me a couple of times due to me or the wife forgetting to turn them off.
Any suggestions please, of course any advice would be truly appreciated.
Regards[/b]
It will likely be the door switch, to test it push it in/out and watch your courtesy light, if it doesnt turn on/off then thats the problem.
Its usually in the doorway and behind a Black rubber boot that you can push in, there will likely be a rubber bung on the door that hits it.
A pozi screwdriver will remove it, allowing you to pull it out and clean the contacts etc.
Hi Mattylad
Sorry I should have made it more clear, it is when I leave my side lights on, this is draining the battery.
The courtesy lights go on and off as normal.
Regards
Hi Mattylad
Thank you very much indeed, it was the switch which was causing the problem, the spring inside the actual unit was sticking so a little clean and by simply reversing it worked a treat.
Once again Thanks.
