Thanks for replying, Was looking at the 6mm NMP. The floor was 18mm Chipboard but I have now replaced 90% of it with 18mm Ply.
I like the idea of the NMP, its stuck down with high strength adhesive in a tube and then screwed. Where as the 6mm Aqapanel states it has to be put down with Tile adhesive, which is more of a faff. However the Aquapanel comes in larger sheets which I prefer, do you know if the Aquapanel can be stuck down with the NMP recommended adhesive.
