I feel like I have been royally ****ed over in hindsight by a builder who has done my garage conversion even though at the time I was really happy with the work. The council building control officer has also been absolutely useless and hasn't mentioned multiple things I've come to find out should have been done at the time and still signed it off as 'to building regs'.
Anyway I found out I should have ventilation in the small roof void above the garage conversion (it's now a living room), I'm finding out the best way to sort that.
I've also now just come to the realisation that I have no airbricks installed for my wooden subfloor. How likely is it I'm going to run into rot issues if I don't get these installed? It seems like not many conversions actually have them but then I don't know if their subfloors are concrete whereas mine is raised timber.
The thing is the subfloor is raised timber and chipboard and has kingspan insulation in-between the joists so I don't actually see how airbricks would ventilate under here as there would be nowhere for air to flow anyway? There is a drain grate in front of the bricks where there 'should be' air bricks' so them bricks will never sit in water or anything, its an insulated cavity wall.
The subfloor sits on a concrete slab which is about 150mm lower than the rest of the house (also on a concrete slab). When a pilot hole was drilled there was found to be a vapour control barrier installed under the concrete floor.
