Moved into our house in Dec03. The boiler is a Vaillant VCW-Sine 18 T3 WF H 'combi' boiler which does heating and on-demand hot water. I was told by a plumber (CORGI) guy who called to connect our new cooker that this boiler is "a decent one". It has worked fine for months and now it seems to have packed in completely! The symptoms are : Pilot light is alight, but no 'big flames' ignite when the heating is turned on (wall mounted computer), or a hot tap is turned on (cold water only comes out). The problems started when I turned off the mains water to plumb in a dishwasher under the kitchen sink. Did that ok, but stupidly thought I needed to turn boiler pilot light off while mains was off. Big mistake! At first on restarting the pilot wouldn't stay alight (it kept going out after lighting, until I held the green button in for a 1min instead of 10secs...borderline thermocouple!), then when I got that going, no hot water or heating. The system is pressurised at spot on 1bar (I have tried 0.5/1/1.5/2 with no luck). I have bled all rads, and all air from boiler (including topmost bleed valve). The main control unit makes the correct relay clicks when CH/HW asked for, but the pump does not start. At first I looked at the water-difficiency venturi/diaphragm/valve, but then realised that this would probably work if the pump was running. I have checked for power to the pump and also at gas valve solonoid. Nothing at either (suggesting both are ok, but the control PCB is not sending them a signal). I have also fiddled with the NTC and the flow-stat. EVERYTHING I do gets me nowhere! I am running out of ideas. How could plumbing in a dishwasher knock out the main PCB?!?! It's a totally seperate system!! Fuses are ok. All looks ok. Any ideas? House is freezing! Wife is complaining!! I am an engineer by trade (with degree) so I'm one of those "I'm not paying to get a plumber in, I'll fix it myself!" people! Trouble is I've been messing with this thing for 5 days and I'm getting nowhere!! Help!!
