My girlfriends heating has been playing up for a while and I've tried my best but could do with some advice/ideas! HELP!!
She has a Potterton Suprima 30 boiler with a Potterton EP2002. The board inside has been previously changed due to common problems but I don't think it's the boiler that is the problem now.
http://img844.imageshack.us/img844/7164/34808995.jpg
http://img17.imageshack.us/img17/601/38745017.jpg
Intermittently the boiler will turn off and we cannot get the heating back on. The EP2002 is still lit up for the heating but the boiler sits there with light on solid amber (no call to boiler).
http://img197.imageshack.us/img197/7767/41301781.jpg
http://img571.imageshack.us/img571/6817/14002085.jpg
http://img834.imageshack.us/img834/9531/84255980.jpg
I've tested the switched live when we have the problem and there is a small voltage (nowhere near 240v that it has when working), around 90v as pictured
http://img211.imageshack.us/img211/1356/19110949.jpg
..and that changes i think, don't think it's always 90v. Pumped live also has no voltage through it when it isn't working. Live always has 240V
Due to the above I replaced the Potterton EP2002 with a new Potterton EP2002, thinking this was the problem. It is still a problem intermittently problem with the new EP2002 (about 50% of the time it doesn't work). Sometimes the heating will only come on if you turn the water on too, sometimes cutting all power to the boiler and timer and turning back on after a few minutes will make it work, and other times none of this works!
I've checked the thermostat and when it isn't working this also doesn't seem right, it has 3 wires, one neutral, permanent live and switched live (am I right). When we have problems with it there is no permanent going to it.
http://img145.imageshack.us/img145/9923/77370210.jpg
http://img708.imageshack.us/img708/8370/14478857.jpg
I'm guessing the wiring is okay as it does work around half the time, sometime for days at a time (strangely it seems to work for longer when I've messed with the EP2002).
http://img577.imageshack.us/img577/5745/33049256.jpg
ANY help is really appreciated! Currently sitting here warm with the heating on, this could change any minute!
Thanks!
Russ.
Thanks!
Russ.
