Hi all,
I’ve recently moved house and inherited a Worcester green star heat slave 12/18 with a Honeywell wireless thermostat.
A day or two ago we lost central heating. The hot water works fine as the boiler fires up.
However there is no heat in the rads throughout the house.
I bled the rads thinking there was possibly an air lock.
And set the stat at 25c.
I’ve re-paired the stat and also bypassed it by jumping terminals LR and LS in the boiler.
The diverted valve actuator is a Drayton 27900 and appears to move when the stat is over ridden but central heating still doesn’t work nor does the boiler fire up.
Is it sensible to assume the valve is shot or are there other things I should check first?
Many thanks
Many thanks
