Hi Guys
I hope somebody can help, will be very grateful if you can. As we are now entering winter, I thought I would stick the central heating on but there is a problem. None of the heaters are warming up, both upstairs and downstairs but I am getting hot water without any problems. I am not an expert on this matters (as I guess u would of worked out, hee hee). There are three main pipes coming out of the bottom of the boiler two are close together and are boiling hot, I imagine this is the hot water, one of these pipes has some sort of valve on it. The other pipe is only warm at best, I assume this is the CH but not sure. The raditors have been bleeded but no joy. Do you have any ideas on what I can do next?. Is it worth bleeding the circulation system to solve the problem. I can send pics of the system if this helps.
Thanks for any help that you can give
Martin
Martin
