- Joined
- 5 Nov 2012
- Messages
- 2
- Reaction score
- 0
- Country
Hi there, looking for a bit of advice before I have to call a plumber!
The cold water tap in the sink in the bathroom stopped working a while ago, it had very low pressure to start with but eventually it stopped working. Now I can hardly even turn the tap as its totally stiff.
The cold water tap in the bath has now stopped working, unlike the sink I can still rotate this fully. No water not even a dribble comes out.
I have read a few things where it said it might be the washer or an air lock so I took apart the tap and the washer was metallic and only covered 3 quarters of the way round but appeared completely fine. I then blew down the tap with a straw but when I put the tap back together no joy.
Also, and this may be unrelated, my overflow pipe at the back of the property drips quite a lot of the time but I can't work out when it does it or indeed why.
As you can guess I'm pretty clueless with the logistics of plumbing but willing to give things a go. All help appreciated!
