HI All
Heres the brief sequence of events......
1) Power shower pump stops working.
2) Isolate shower supply using inline valves.
3) Inline vales not completley stopping water so turn of house water supply.
4) Drain tank using upstairs tap
5) Fit new shower
6) Turn on Manis water and shower valves.
Outcome - No water pressure upstairs ! The three valves i have touched are all open, the cold water tank is full. When you first turn the tap on it seems a little slow but it then pretty much stops.
Ive tried leaving the tap running thinking it might be an air lock, ive plungered the tank on teh roof on the outlet providing water and even flushed the loo in a vauge attempt to get it to work
PLEASE HELP - I turn the upstairs taps on and get a small trickle which then pretty much dries up. The water downstairs is fine and the tank refils ok.
Any ideas ?
Gareth
PS - The hot water and water down stairs is fine !
5) Fit new shower
Any ideas ?
Gareth
