Hi
Combi Greenstar 24i had a new heat exchanger and an expansion vessel replaced 6 months ago. Today the CH is fine, pressure looks fine about 1.5bar
but the HW when running gets really hot then stops and you can hear the boiler sort of cycling then stop and then it sound like the fan goes off and on repeatedly for a 30 seconds if you stop the HW, after a few seconds the boiler goes quiet and when you run the HW tap again after about 20 seconds you get the same really hot water suddenly then it goes cold then the boiler goes through the same cycle again.
Any idea would be appreciated
