I am wanting to replace an old corroding radiator and to do this I have to drain the system, however there isn't a drain valve.
I understand I have to shut the water off, and somehow drain the system, but how do I do it.
I will want to fit a drain valve to an exhisting radiator for next time. Which way does the water flow in the radiator? which will help me when re fitting a drain valve, using a lockshield incorperated.
Is it possible to use compression joints on the pipe work leading up to the rad?
Is it possible to use plastic pipe for ease of resiting the new rad?
