- Joined
- 13 Apr 2021
- Messages
- 9
- Reaction score
- 2
- Country
1 Radiator not working, checked some forum tips and Ive ended up replacing Radiator, TRV and Lock Shield, as they were all very old, this did not help. There is an isolator on feed and on return plus a drain valve in between. So I shut the Isolator on return and opened up the drain valve and water came through with good flow via the feed pipes, through Lock shield, the radiator and TRV (bi direction) let this flow for a few mins to ensure no air trapped. Did the same in reverse ie closed Isolator on Feed and opened the isolator valve on return and again good flow of water, showing no blocks and water was clean, there was some air but let it run till all gone. Still the same issue, so water pressure builds but is not being pushed through. I considered the system needed balancing in which case, so I shut off all radiators but the one not heading and the bathroom (600mm) as it locked open. Radiator started to warm but took 1hr to get enough water to the return side of the radiator!! As soon as the other radiators were turned on back to no flow of water. Struggling to think what else it could be. any thoughts would be appreciated.
Its a sealed pressure system with a Logic Combi c30 boiler, less than 2 yr old with only 6 radiators. Problem started when there was an interruption to the gas supply. although its hard to imagine a link between them.
