Help needed,rads not getting hot upstairs.tied to bleed..no pressure.up the loft to check header tank...no header.checked the cold water tank.the filling pipe is way above the water level.about 20mm below the incoming valve.suggestions please.the system is a old back boiler/gas fire.thanks in advance.
