Previously my boiler packed up (//www.diynot.com/forums/plumbi...ease-not-running-heating-or-hot-water.387918/) - new air pressure sensor fitted but now it's only heating hot water, not the radiators.
The guy who diagnosed the initial problem and fitted the new sensor said the heating not working would be the controls or the room thermostat. So I switched the HW and the CH wires in the controls and calling for CH turned on the HW as expected. It's obviously sending the message to call for heat so I switched the wires back to normal.
Assumed this meant the room thermostat was at fault. I replaced it and the light comes on on the wall unit when it's calling for heat. However, the boiler does not illuminate the lights, not even the "boiler on" light.
I'm now lost - anyone got any suggestions please? I have a "Y" valve upstairs and pushing the motor to the CH setting fires up the pump and the boiler ignites as it should. The controls are fine, thermostat fine (I believe) and boiler is operational. What does that leave?!
