Last November, we had a loss of heat to the ground floor radiators and British Gas engineer suggested a power flush. Then we called the local plumbers (who originally installed us a brand new Worcester Bosch boiler two years previously).
So after reporting the problem last year the local plumbers only changed one of the pipes in the airing cupboard somewhere around the pump and how water cylinder. They showed us the pipe afterwards and it was almost totally blocked with black stuff. They did not do the power flush as they said the radiators and pipe system are old (20-ish year old), and all they did was to add Inhibitor and Sentinel X200 to the system. The job they did seemed more or less OK, just one of the radiators on the ground floor (furthers away) was always worm-ish, rather than hot.
Now, a year later - we have exactly the same problem - no downstairs heating! I have shut down all the radiators on the first floor, yet the ground floor radiators good few hours later are only lukewarm. The main pump seems to work, I can hear the noise and flow through the pipes around it.
In your opinion:
- should we do the power flush?
- is there any alternative to it (ie: chemicals) ?
The house has:
First floor - 4 radiators + 2 towel rail radiators (which do heat up if open)
Ground floor - 5 radiators (4 get lukewarm if the above are shut, the furtherest one is cold)
Any suggestion or recommendation will be greately appreciated!
In your opinion:
The house has:
