I have a 20+ year old baxi boiler. Recently I switched some of the radiators off so I can have hot water without having the heating on (both valves wired into timeswitch instead of being seperate- long story). This was working fine until a few days ago when I noticed the boiler was cutting out after only a minute or two. (I also switched the radiators back on).
The pipe to the pump is hot and the beyond the pump the pipes are also hot right into the top of the hot tank. However the water from the tap is luke warm and the radiators are cold. The pump is vibrating and seems to be working but it's making a bit of a noise. This has happened before with the radiators when they were switched off all summer and I had to get someone in to flush the system which was full of sludge.(according to plumber the system doesn't have a drain valve so he drained it from radiator?? even though it appears not to be a sealed system)
The pump was replaced 3-4 years ago and the themostast 2 years ago.
I've tried bleeding the pump and the radiators. I was thinking of replacing the pump and if that doesn't work I going to try and drain the system , as I found a valve under the hot water tanks which I think goes through to an outflow in the wall.
Any suggestions?
Any suggestions?
