We had our approximately 7 year old logic combi 30 boiler moved earlier this week. It was only along the wall about 6 foot so no major pipe changes and this was done by a registered gas safe engineer.
The following night we tried to turn our central heating on. The first two in the chain got semi warm but stayed mostly cold at the bottom and the return pipes remained cold. No other radiators heated up at all. We bled the radiators, this did nothing. We tried balancing them. Nothing.
The engineer came back and suggested its a blockage as the boiler fires up for about 50 seconds then powers off. After a few minutes it fires up again then this repeats itself. He said to empty the radiators, run the system through using the filling loop then refill. This did nothing.
We have tried closing the valves to each radiator. This does nothing.
Today we put some sludge removal in the system. This also did nothing except make the boiler make some horrible gurgling noises. We bled the radiators (not that much air came out at all) and tried again. Again, it still keeps just firing up for 50 seconds or so then resetting.
We think it's unlikely that it's a blockage because although the boiler itself is around 7 years old, the radiators and 90% of the pipework are only 2 years old. We haven't had them on since March (ish) but they worked perfectly then.
The pressure is absolutely fine and doesn't budge. The pump sounds like its working and is hot when the CH is being called for.
Interestingly, whenever we've drained the system down relatively close to trying them, the return pipe feels warm. This suggests there's no blockage right?
No error codes come up on the boiler either.
Absolutely no idea what to try next - is it a new boiler job?
Sorry for the long post but its been a very cold, frustrating few days!
Thanks in advance.
Thanks in advance.
