Hi - help needed...
I have an issue with a Potterton 28i
Selected Hot water and central heating
Have hot water, burner switches in and out when hot tap is run
Central heating water pressure = 1.25 Bar
No heating
LEDs:
Power on - Illuminated
DHW mode - Illuminated
Central heat mode – Never illuminates
Red LEDs display temp (~70C), no fault LEDs.
Pump (Grundfos 59926502):
With power off, removed bleed, not seized.
Has power supplied to it (pump has no LEDs on it)
Measured approx. 100ohm resistance across Neutral and Live
It is very hot
Control:
Thermostat – OK (tested by bypassing)
Built in timer/controller – Tested and OK
PCB – exchanged but fault still present
If the pump is at fault would I still see the heating demand LED come on? (As said mine never does).
Could it be constantly requesting hot water and so never heating?
Any advice welcome!
Cheers
No heating
LEDs:
It is very hot
Control:
Any advice welcome!
Cheers
