Hi All
I'm having a bit of trouble with my central heating system & hope someone can help me!
I live in a 6 year old property which we bought 3 years ago. Since we moved in we have only been able to get CH when the HW is on. I though that this was how our system worked (my old flat was like that). However after reading about balancing the system, I found this website & read the FAQ's & visited the forum, so now I think that our MV is at fault or the wiring to the circulating pump is wrong. Hopefully someone here can help!
Here is my system specs anyway:
Ideal Classic FF 330 Boiler
Grundfos Alpha Circulating Pump
Drayton MA1 Midpoint Motorised Valve
Lifestyle LP522 Electronic Programmer
Drayton RTS1 Room Thermostat
System fed by feeder tank in the loft.
The MV is midpoint 3 way & comparing the diagram on the MV instructions to the wiring centre it has been wired for independent CH. (there is a red wire from the programmer with a grey wire from the MV & a wire from the cylinder thermostat in the same hole on the wiring centre).
I've looked at the programmer & it too has been wired for independent CH. There's nothing glaringly obvious that is wrong on the wiring centre.
When HW is selected on the programmer the MV indicator moves to H & the pump comes on.
When CH+HW is selected the MV indicator moves to M & the pump comes on.
When CH is selected the indicator remains on M & doesn't move to H. The pump doesn't come on.
So I'm wondering, is the MV is stuck, or is the wiring wrong? Has it been wired so the pump won't turn on for CH only? I mean if the MV won't move beyond M to H, wouldn't the pump come on anyway & I'd get CH+HW?
If it's the MV that's great as it's covered under British Gas. If it's the electrics, I'll have to get a Sparky in.
Many Thanks for any help. I'm driving my wife nut's with this as it's become a bit of an obsession!
I should also mention that the water cylinder has a thermostat. This means that as we can only get CH+HW, the heating sometimes cuts out when the tank is fully hot. I've pushed up the thermostat to stop this, but this makes me think even more that we should be able to get CH independently.
