- Joined
- 24 Sep 2020
- Messages
- 5
- Reaction score
- 0
- Country
I will try give as much info as possible to help.
Vaillant ecotec 24. Problem started a few weeks ago with F75 error code and having to keep resetting the system to get hot water to work. I changed the pressure sensor and sorted out the F75 error and the pressure now rises as it should when the boiler turn on. Set at 1.5 and rises to 1.9 when the boiler is working. As it's getting colder outside I turned on the heating and it isn't getting the radiators hot. I can hear and feel the pump working so it isn't that. I thought it might be the diverter but as I turn the water on or off at the tap I can see the rod pushing in and back out accordingly and no water drops from this either. Hot water still getting hot at the taps by the way.
When I initially turn the heating on the boiler fires up as normal but then turns off as the temp rises to around 75/80 and the pump over runs as it should. Could it still be the diverter valve even though I can see the rod moving???
