No heating
1 Oct 2006
Staffordshire
I have a Glow worm boiler. Hot water is fine. Boiler does not fire when heating switch is turned on, any thoughts?
Excellent post, concise and to the point. Thoughts whirling around my head as I type this. Aha, got it.
I also have plenty of thoughts as well.
Those which are printable and about your problem is have you turned on your rad valves, your thermostat and the programmer?
Tony
I have a Ford car. The engine will not start, what could it be?
If this is any help, I bought it some time between 1928 and 2005. The key turns.
He has a "control panel" !
I wonder if this is a programmer?
Do you have a hot water tank ??? Big copper thing in the airing cupboard?
Do you have a " motorised valve" which has got stuck??? Tried moving the lever at one end ???
Tony
