I've replaced my Drayton TA/M4 valve with a Honeywell 4073A and completely rewired the system to a Y plan (Yes! you do have to) thanks to some advice from you lads.
My problem now is that everything seems to be doing what it should as per the controls, when the valve switches to hot water only the top of the heating coil gets hot and the bottom remains cold.
The top then seems to cool down shortly after.........I think this because the boiler cuts itself off.
Heating seems fine ....Rads up and down hot when they should be.
It seems water not flowing through the heating coil but it has one of those bleed caps and I've been bleeding it (little bit of air each time)
What now?
Boiler is Ideal Standard WRS
What now?
