I currently have only occasional Hot water from my Swiftflow 100 boiler i.e every now and then it will work. I have bypassed the DHW Flow switch with the water flowing and the boiler fires up no problem.
I therefore assume the problem is with the DHW Flow switch although the water pressure seems low and I only replaced the flow switch around 14 months ago. If I run the water and tap the switch this makes no difference.
I guess my question is; if the ball in the flow switch jams does this reduce the flow of water to the taps and if that is not the case is there anything else in or around the boiler that would cause low pressure as mains pressure seems fine. There is a spherical object which comes off the feed pipe just before the Flow switch but I don't know it's purpose.
Any advise would be much appreciated
