hi. i was wondering if anyone can help me.
about a week ago the hot water in my house lost pressure and also started to take about 5 minutes of running before it became hot. i have an oil tank here and my boiler is a 'boulter combi 70, camray 5' when i checked the oil i noticed it was very low so i put the problems down to this. Yesterday however i had some more oil put in and still the problem persists. as soon as you turn the hot water tap on it comes out at normal pressure for about 5 seconds then reduces to almost a trickle.It then takes 5 mins of constant running/trickling to go warm(at best). The pressure in the cold water tap is ok and, i don't know if this is relevant but the central heating works fine also.looking in the boiler i've noticed the pressure gauge is at about 1 and a half but the gauge goes up to 5, i don't know if this has changed or always been at 1.5 because i've never had reason to check before now.
Anyones help in this matter is greatly appreciated.
