no hot water/ C.H ok ??
29 Mar 2006
Tyne and Wear
i took my radiator of as it was leaking. i drained down the system as the valve were broken. i capped the 10mm micro bore copper pipe off, both ends. turn the combi boiler back on and .....no hot water. but my C.h is fine.
can you help ??
did you top up the system again??
do a search on filling loops if u didnt
