I have been recently doing a lot of work on my house which involved temporary removing three out of 8 rads, two upstairs, one down. (skimming walls).
They were off for a couple of months and I have recently remounted and reconnected them.
During the period they were off I noticed the CH pressure had dropped to zero. No problem, I havn't been using it through the "summer" !!!
I followed the 'sticky, how to' yesterday to refill and repressurise the system and all seemed fine.
But, for some reason whilst I was doing this I manged to turn the filling loop fully on, rather than off !!! The pressure obviously went to 4 bar and the boiler started making a loud banging and started venting the water out of the vent pipe outside. I then noticed my mistake and turned off the filler tap, after about 10 min !! again !!
It all settled down and I thought it was fine. But now the CH pressure is back at zero and I dont seem to have any hot water. The boiler fires up initially, when you turn on the tap, but then goes off and I just get cold water out of the tap ???
If I try to bleed any rads, I just get water, no air.
Does this sound like something simple or do I need to get a engineer out ??
The boiler is a Worcester Bosch 35 CDi
Sorry I dont know its age, I would say between 5 - 10 yrs. I also don't know its service history.
Thanks in advance. Please be gentle, 'lectrics, , plumbing/CH
