I've already read a few previous posts on this topic and I'm starting to think the mixer tap has had it, after only 4 years service.
Just so there's no confusion, I'll list the problem and everything to date I've tried and am hoping there maybe another option than replacing the tap (as it's a swine to access and took a while to fit!)
About a week ago I got intermittent flow from the hot tap, which came and went. Two days ago the hot water stopped all together, with one or two moments of it flowing slowly, then the flow dying away to nothing. It's now not working at all.
The hot water is supplied from a combi boiler about three feet away from the kitchen sink, drawing from the water mains, not a tank. The shower and bathroom hot tap are receiving hot water with no issues, just the mixer tap is at fault.
So far I've:
Tried holding a towel / sponge over the tap, opening the hot tap, then opening the cold tap and holding it for about 15 seconds = slight water spray everywhere and no hot water.
Hooking up a hose pipe with tap connectors from the cold tap in the bathroom, to the mixer tap. Open up the mixer hot tap, flow cold water from the bathroom for about 15 seconds = amazing water spray as the bathroom taps have lever arms that hit the top of tap connectors, so you can't fully shut it off before removing the connector and still not hot water.
Cleaning out the tap doesn't seem to be an option, as it's a Wickes Trade Mono Sink Tap and doesn't appear to come apart. (unless anyone has different experience of that?)
I've checked the metal flexi pipes that connect the tap to the original copper pipes, there are no kinks or pinching at all.
Lastly the water pressure is very good in my local area, since Thames Water upgraded the pipe network, I don't this is a factor at all.
Fingers crossed there is one more thing I haven't tried and don't know about, or is it time to hit the DIY store for a new tap?
Cheers
So far I've:
Cheers
