I am looking for advice about a problem with hot water from the kitchen tap. We have an Ideal Logic 30 combi boiler, It was installed in our new build house 1 year ago. We are having problems with the hot water from just one particular tap. It had worked fine before, but in the last couple of weeks has got progressively worse to the point there is no hot water. All other taps in the house trigger the demand for hot water on the boiler instantly, but when you turn on the kitchen tap the boiler just sits there on standby. It is the furthest away from the boiler and being a new build eco friendly house the tap has a flow limiter fitted. The mains water pressure has seemed to have dropped recently, maybe because more houses have been attached to the water system in our large estate and the mains water pressure is low here anyway. When the hot tap is turned on fully the water comes out at less than 2 litres a minute, the cold is exactly the same. Is the problem with the “save the world” eco tap? Or maybe a problem with the boiler itself? It does seem to me even though I am uneducated in the world of plumbing to be an issue with the tap as if it was the boiler, the other taps would have the same problem.
The hot water sometimes comes out red hot then goes cold, but it has always done that, even though a bit more frequent recently, is that a low water pressure problem also.
Any help or info will be greatly appreciated, as the only way to get an hot water from the kitchen tap is to set it running and rush off to another tap, turn that on to fire the boiler and if we are lucky the boiler then keeps running and we get hot water…….and it is now driving me mad.
Many thanks for your help.
