I have recently installed a kitchen mixer tap (shower head type) and have not been able to get any hot water out of it.
I tried to solve the problem by installing a single pump (Contract Twin 50) to boost the hot water supply to the tap. Unfortuntately, it seems that the pump cannot be activated when the tap is connected - I think the low pressure drawn by the tap is too low. Without the tap's flexible tubing and turning on the flow at the isolation valve, the pump works fine.
Apart from getting a low pressure or perhaps a negative-head pump, what else can I do to resolve this problem?
many thanks in advance
