No Hot Water - Heating working fine
22 Nov 2004
Hampshire
Hi
Starting today, the hot water on my Combi boiler has failed. The central heating works very well and so has the hot water up until today. Now however, the hot water it remains cold. There are no warning indicators on the boiler to suggest any problems but clearly there is one. I took a brief look at it myself, fiddled around with a few sensor connections, added a very small quantity of extra pressure, fiddled with the hot water control and for a time it started to work again but its failed this evening yet the central heating is working perfectly. I feel as though when I switch on the hot water, the central heating heats up but that might be my imagination.
When I switch on the hot water and go to where the boiler is, it fires up with all the correct lights etc but fails to provide me with hot water.
It's a Baxi HE133 Plus. 3 years old and has worked absolutely brilliantly up until today.
Any "Genuine" advice would be appreciated please. I am only interested in what the problem might be, thanks.
Diverter valve stuck in CH position and not returning.
(Also the thing about western capitalism)
The diverter is motor driven and the mechanical part is probably stuck. Its fairly common on your model.
You will find that turning on a hot tap for 10-15 minutes will cause the rads to heat up!
Tony
I wish I'd thought of the diverter valve.
Blimey you wait a whole hour for a diverter valve diagnosis and then three turn up all at once.
I thought that softus had thought of it but had not explained exactly how it had failed ( or that the rads will be heating ).
He was very clear that he only wanted genuine advice on exactly what the problem is! I suspect he wants to fix it himself!
Tony
Well at least he's got a second (and third) opinion if he's the doubtful type :LOL:
Diverter valve is stuck........
Remove the actuator head, (press 1mm² button underneath and twist 30°)
Check actuator head is not stuck in c/h mode (pushing spring in).
If spring assy won't move with thumb pressure... Using pliers push/pull spring assy until free.
So its the diverter valve then? :):):) From what you all say, that sounds about right in my book.
Thanks for the mass of responses. I will be attempting this myself
as it does not sound too difficult. Whilst I was looking around yesterday I found what I believe to be the Actuator (well it was a black box with the words "Actuator" written on it) so I will look at trying to fix it before calling in the experts. Of course, its on my head if it goes wrong.
To clarify, is it a case of just removing the Actuator box and then easing the valve and spring? Are there any water valve's I need to turn off. (yes I know to turn off at electric). Will the Gas supply need turning off?
Thanks!
You have a good book there.
See baxpoti's post.
No.
No.
Have you got a brother called Colin?
