Hi guys,
So one problem after another, I dont ever recall the hot water ever working in the ensuite shower. It currently has a triton mixer shower, the cold water works fine and the stop valve is in the loft. The setup is a cold water tank in the loft, hot water tank in the airing cupboard and gas boiler in the kitchen. With the cold water valve off (this feeds the shower directly) we tried to see if any hot water (any liquid) will come out but no luck.
Now we're tried to trace the pipes and figure out that is wrong as currently we hit a dead end and even thinking no hot water pipe is even attached!
from the airing cupboard, the hot water pipes go down and under the bath tub, picture below.
The first 4 from the bottom, i'm guessing are central heating, the next one up not sure, the next one up with the white hot patched going up is the hot water for the bath (next it is the cold water) then the last one not sure. But only the tap basin hot water works, shower no hot water or any water.
Any ideas, all valves are on, I recall when i took the mixer shower unit off, both pipes were dribbling with water. I'll get some more pictures on tuesday.
