I had to change a valve in the bathroom radiator because of a constant leak. I drained the system as best i could and replaced the valve this was done however there seemed to be a lot of water still in the system so maybe it wasnt drained properly, I just used used loads of towels to mop up the spillage.
I refilled the sytem and bled all the radiators
Now for the problem.
Downstairs 4 radiators are all working fine in fact they seem far hotter than normal.
Upstairs 4 radiators are stone cold not even any hot water in the pipes leading up to the valves.
I bled these upstairs radiators and eventually the air went and water came out so i know there is water in them.
Any ideas would be greatly appreciated.
I should say that before the draining the system was working perfectly apart from the dripping valve.
Oil fired boiler with tank in roofspace.
