Could anyone enlighten me as to why I have no hot water going to the bathroom sink upstairs even though the bath hot water works, also the kitchen sink downstairs mixer tap is not working on the hot side or sometimes it gets a little warm but not hot as it used to.
Firstly have you got a combi boiler if so which model i had a compact doing what you describe it was the diaphrham split would work on the bath but not the basins because the pressures were greater on 15mm pipe work
