Right, please bear with me. I need your help sorting out my hot water issue, as the plumbers that our landlord uses are useless.
First, let me explain what has happened so far, and then if you can help, please do.
When we first moved in, there was no hot water and leaking. The timer was not turned on, so the plumber turned that on. He also resealed the bath, as he thought that was the source of the heating.
The hot water was fine for one night. So out they came again, and replaced the bit at the top of the immersion heater. He also could not explain the leaking.
The hot water continued to last only one night, and the leaking continued. Another plumber came out who said that the thermostat had tripped out, so he reset this. He also replaced the Salamander shower pump thing, as he said that that was causing the leaking.
This was fine, except now, we only had about 2 minutes hot water out of the shower. Every other tap had constant hot water until the immersion heater was empty.
We complained so much to the landlord, that they agreed to get another plumber out. The new plumber replaced the top bit of the immersion heater, the element, and re-did the pipe work.
This has been fine for about 1-2 weeks now, but today, it has stopped working again. Nothing has changed, but we have no hot water coming out of any taps.
Anyone got any ideas?
