No Hot Water No heating Rads half empty
31 May 2006
Buckinghamshire
Heres the info
Baxi Boiler
Grundfos Selectric pump
got up this morning to no hot water, the pump is very hot to the touch and the boiler does ignite if the stat is turned right up, it then boils the water in the boiler and turns off. I wen to bleed the rads to see if it was an airlock and their isnt much water in any f the upstairs rads, is this just the pump has gone or is there a problem with the incoming water supply. All taps in the house have water
thanks in advance a cool and unwashed Remoh1
Baxi what? Combi?
If there's a small header tank in the loft make sure it has water in it.
ChrisR said:
Baxi what? Combi?
spot on ChrisR
ball valve had stuck. I have now sorted the valve and the tank has refilled, had to take out the bleed screw in the pump and turn manually to get some cold water into it and leave it to cool down before it would restart now all I have left to do is to get the air out of the system, I had the pump on 1 and bleed the rads, turned pump to 2 heard more gurgling so i bled the rads its now on 3 and I have just bled the rads again. I will reset it to its orginal setting of 2 shortly then bleed rads again later.
Thanks for taking the time to answer my question ChrisR
