Hi There,
I have tried to scower the various on line forums to try to resolve my problem but have been unsuccsesfull.
I apologise in advance if the questions i ask seem silly or confusing, i will try to explain the best i can, any help to the following will be very much appreciated!
We noticed that the hot water started to take longer coming through over a period of two weeks (water supply still ok, just taking longer to get hot), now it has stopped completley (just cold water). I checked the central heating and that does not work either now!
When the hot tap or heating is turned on, the bolier makes all the usual noises (rush, click click click etc etc) but to me just seems like it fails to ignite.
The pilot light is on and the water pressure is ok, i have removed the panel from underneath and can see three main components. one of these is for the hot water and the other one for the heating (i assume), both have a"pin" like bit that moves in/out when it see's a demand from either the hot water tap or the heating being turned on, and activates a limit switch (which makes a clicking sound).
I have been asked to check to see if the pump is running, but i do not think i have one, i think that possibly the water pressure is provided from the mains supply??
As previoulsy mentioned i know nothing about boilers but I am an engineer, so i do not mind having a go myself - if only i knew where to start.
any adivice, help or further direction will be greatly appreciated
Martyn
Martyn
