I've got no hot water working...but the central heating works.
Can anyone post any advice on what to do about this? I've followed the FAQ about manually opening up the valve and turning the heating on. For some reason, no (hot) water seems to be going through the (now manually opened) valve. The central heating is definetely working, but nothing from the hot taps. I've got two separate valves - both 2 ports. The heating one is controller by a Drayton and the hot water one is a Honeywell.
Pressure seems to be at the right level.
When I switch on advance for hot water (leaving heating off) from the programmer, the boiler doesn't operate at all - no noise, nothing.
I also think that the element in the immersion (Santon PP150B) has died too since when I switch on the hot water switch, it lights but nothing happens even after several hours - it's been on for over a day now.
Will the system just point blank refuse to supply hot water if the element has gone in the immersion?
Any help would be appreciated at this point.
