I have had a relatively new hot water system (less than a year old) and we have had a gradually developing problem with hot water pressure. the system is a standard gravity fed system with a cold tank in the loft and the hot water cylinder directly underneath. We have recently only been able to get 1 bath of hot water before the hot water pressure goes and only a dribble comes out of all hot taps in the house. The cold water pressure coming out of the same cold water tank appears unaffected.
Up until yesterday we have been able to leave the system overnight and the pressure returns to normal. we do hear some strange sounds from the hot water tank that sound like large air bubbles being released in the tank. Yesterday we struggled to get one bath full of water out before the pressure went and we are still without hot water pressure. If you leave the tap off for a few minutes then you do get adequate pressure from the hot tap but only for a few seconds and then the pressure dies again. Does anybody know what this may be caused by and if there is a simple solution???
