We have a Worcester Bosch R35HEPlus combi boiler. We have been experiencing for quite some time now no hot water from the tap in our downstairs cloakroom sink. We recently changed the sink for a larger one and replaced the tap for another but this did not cure the problem.
Several months ago we could not get hot water anywhere in the house and ordered a new 3 way diverter valve but ended up returning it as the hot water mysteriously came through again. The problem still remains with the one tap in the cloakroom only. I have researched this on-line looking for people with similar trouble and have seen suggestions that it could be a stretched or split diaphragm causing it.
I have consulted the installation and servicing instructions that came with our boiler but the only diaphragm mentioned is in the mixer unit assembly. I am unsure as to whether this is the same type of diaphragm, or can you only replace the diverter valve on this particular boiler? Would replacing the diverter valve be the answer to this problem?
