I'm running a conventional potterton Netaheat boiler. The hot water won't warm up unless the heating thermostat clicks on. I flushed my heating about a month ago if it helps. The motorised valves both appear to work as they should.
Is it possible to get air in the hot water system causing the boiler to overheat with only hot water on?
