No Hot Water - Worcester 24LE RSF - Rads are OK
12 Mar 2008
London
Please Help - I have no hot water.
I have a Worcester 24LE combi gas boiler (same as the 24CDi RSF but with the onboard programmer)
I recently had a radiator removed from a room downstairs along with the kitchen sink (the sink taps have temporarily been disconnected due to new kitchen being fitted) at exactly the same time there was a major water mains leak outside a few yards away from my house (the water leak is a recurrent theme but has now been temporarily repaired).
The water pressure in the boiler dropped to about .8, the red line marker was set at 1.0. After this, hot water was a bit erratic, sometimes only being able to get a reasonable temperature when the CH was switched on. Then it stopped altogether. The pilot did not fire up when the hot water tap was turned on.
From this forum I was able to work out how to increase the water pressure and did so, raising it to 2.0.(thanks, I owe you all already)! Now when I first turn the tap on the pilot does not light up however sometimes for about 3-4 seconds it seems like the water is getting hotter then it reverts back to cold. I am assuming the trickle of warm water is something residual as a result of the CH and not the DHW. The radiators are working fine and the pilot light is on and fires up for the CH as I would expect i.e. when first switched on or to regulate dips in temperature.
I don't know if the removal of the sink/rad & or mains problem are red herrings. Any ideas?
I am sure this has a flow turbine in it and not one with a divertor valve.
I would opt for a new one of those.
Might be pesky dirt out the newly repaired water main that has jammed the turbine from spinning hence sensing the water flow to you tap.
Never seen one of them :confused:
It is a BG version of the CDi (IMHO) ;)
HW diaphragm is the likely cause...pig of a job :cry:
