Hi, I have an old Ideal Vulcan Rs55 boiler with gravity fed hot water and pump based central heating. I've recently fit 2 new radiators, 1 upstairs and 1 downstairs which were missing when I bought this house. I drained most of water out while installing them, so I have bled all the radiators a few times since installing them. Even while bleeding them, I had an upstairs old rad that did not bleed a few times (even though it was hot and I think more than 3 quarters full) and when I put the boiler on water only and shut most of rads, water came out of it and I assumed it had bled.
The problem is that I don't get hot water now and not all the radiators are getting hot evenly. The new downstairs rad does not get hot at all.
The worst problem is that if I have my manual timer set to NO HEAT, WATER TWICE, it still sends water to a few radiators and the tap water is still cold, copper tank is also cold and the pipe feeding hot water to copper tank on its top is also cold.
Timely help and bright ideas would be highly appreciated.
Many regards!
psarinuk
_________________________________
Moderator
email address removed, these can be shown in your profile
Many regards!
psarinuk
Moderator
